SamD1
Jun 19, 2021Aspirant
How do I free up local space on Canvas?
My Canvas II says I only have 0.1 GB of 4 GB free. I also have cloud storage I guess. if I try to send a playlist I get an error telling me I'm out of space. How do I free up space using Canvas...
Christian_R
Jun 23, 2021NETGEAR Employee Retired
Hi SamD1,
You may refer to the article below to free up space or use an SD card for additional storage.
https://kb.netgear.com/000060759/How-do-I-remove-an-image-from-a-playlist-on-my-Meural-Canvas
Christian
SonjaCanada
Jan 26, 2022Initiate
Do other users have the same problem as me . . . that often the "answers" from Netgear do NOT answer the question?
When trying to upload a (modified) playlist I am now getting the message "Failed - your canvas is out of space".
I have only 342 pictures in ONE playlist. The Meural stats screen shows that my free space is 3.4GB out of 4.0GB.
Why am I getting this message and what can I do to fix this?
BTW - I can easily upload their sample collections . . . ? I want to completely wipe anything old on the Meural and re-upload my playlist.
Suggestions?
Thanks in advance.
- SamD1Jan 26, 2022Aspirant
I agree, Nergear’s answers seem to miss the point or are a stock answer to a completely different question. Not what I expect for my subscription.
Here is how I have solved the problem of running out is space:- in the IOS app, go to Canvas
- open settings (the cog icon)
- canvas settings
- manage art
From here you remove playlists from your local memory. You can always later send them to canvas from the cloud.
- SonjaCanadaJan 26, 2022Initiate
Thanks SamD1.
Here's the wirdest part. When I go to my android and do what you suggest, under "Manage Art" and then under "Playlists" it says . . . No playlists found. Go figure. I am sitting right next to my Meural watching pictures scroll by. Any ideas?
