vincentVanGo's avatar
vincentVanGo
Follower
May 11, 2024
How to control what Meural shows
I have the Meural I.  I'd like to set the queue of playlists to be not necessarily all images on the frame.  For instance there is a holiday images playlist on the canvas but I don't want it coming up year round.
Second, I'd like to be able to not show some images even though they are part of a "Meural provided" playlists.
When I go to my library, I only see my built playlists, not ones Meural created that I downloaded.  So I don't see how to edit them.
How can I do the above?
1 Reply
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello vincentVanGo ,
    Welcome to the NETGEAR Community!
    I understand that you would like to customize some of the public Meural provided non-membership playlists. The playlists that are found under the "Discover" will not show on your Library since it is a public playlist that has been authored by other users. However, a personal custom playlist can be made from public playlist.
    To accomplish creating a personal custom playlist using works from the public playlist follow the step-by-step guide below:
    1. Open your Meural app.
    2. Navigate to "Discover".
    3. Tap your desired playlist.
    4. Now swipe the photos or works (located above the playlist name) to the left.
    5. Tap your desired photo.
    6. Swipe up then tap Add to Playlist.
    7. Now select your desired Playlist.
    Playlist can be scheduled to play on your Meural Canvas anytime from Sunday to Saturday. At this time scheduling using a date is not supported by our Meural devices at this time.
    To schedule playlist to play at a specific time and day please follow the step-by-step guide below:
    2. Tap "Canvas".
    3. Tap "Canvas Settings".
    4. Tap "Scheduler".
    5. Tap the "Three dots in the upper right"
    6. Tap ""New Event".
    7. Now tap the ">" icon under "Save".
    8. Tap "Playlist".
    9. Select your desired playlist
    10. Now choose the desired time and day that you would like your works to show.
    For best practices, please ensure that your Meural Canvas is updated to the latest released firmware.
    Please follow the steps listed below to update your Meural Canvas:
    1. Navigate to my.meural.com
    2. Select your initials on the far right
    3. Select Canvases
    4. Scroll down to Canvas Software Version
    5. Select the arrow on the right of the software version
    6. Select update on the top right
    Best,
    Kevin
    Community Team
