DharmaBum
May 30, 2022Guide
Images change and menus display randomly (MC327)
I recently purchased a Canvas II (MC327). Love the image quality and subscription service. Like a few others in the forum, I am experiencing random image changes and random menus popping up every few...
- Aug 29, 2022
Original poster here. Happy to say my issue has been resolved.
As others have noted, the issue is due to the gesture sensors. An updated gesture driver can solve the issue, but requires sending the unit to Netgear's San Jose, CA office for the install. Tech support was very helpful in resolving my issue. They reached out to me; I never submitted a ticket.Tech support was responsive to my questions, and followed up with me frequently.
The process was:
- Try a factory reset. This did not solve my issue.
- Disable gesture sensors. This can only be done remotely, and only by Netgear. Once the gesture sensors were disabled, my issue with images changing and random menus popping up stopped completely. I waited a week to make sure.
- With the issue confirmed as due to the gesture sensors, send the unit to San Jose CA for updated drive install. Netgear provided a free Fed Ex shipping label.
This should have been the end of the story. But for some reason, when I got my unit back the updated driver did not solve my problems. The problem persisted until I again requested the sensors be disabled.
Netgear then offered to send me a second unit, but unfortunately, it had the same problems, and I returned it. It came from their warehouse, and did not have the updated driver.
Netgear then sent me a third unit, directly from their San Jose office with the updated drivers already installed. That unit has worked perfectly, without issue. The gesture sensors are enabled and working properly, and the image does not change when "freeze image" is turned on. After testing the 3rd unit for a week, I returned my original (defective) unit to San Jose using the pre-paid shipping label Netgear provided.
For anyone experiencing this issue, I recommend submitting a support ticket and it can be resolved. At a minimum, you can request the gesture sensors are remotely disabled which makes the problem stop (albeit with the loss of the gestures). I worked with Rose in Netgear support.
Pjotrrrrr
May 31, 2022Aspirant
Hi,
I'm having exactly the same problem. I opened a support ticket in January 2021. Last year I've had 2 (!) RMA's.
All 3 Meurals (27") had the same problem.
It seams to be a gesture problem in the whole series that cannot be solved remotely.
The sollution would be to switch off the gestures in the app. But that' s not possible according the technicians.
I sugest to open a ticket. There is not more you can do.
Peter
DharmaBum
Jun 01, 2022Guide
Thanks for the reply. It's disappointing to hear you had three frames in a row that had the same problem. Must be frustrating. It's a shame, because otherwise it's a great device. The gestures are nice, and work most of the time, but I think they aren't really necessary. I'd rather have the hardware/software function properly without gestures, than have it be glitchy with gestures. Seems an option to disable gestures would be really useful, not only to fix this issue, but also for public installations like gallery showings, where you would want to disable access to the menus. Adding this feature with a firmware/app update would be ideal.
- OvecarleoneJun 02, 2022Aspirant
Hi Dharma, I'm now 5 Months in contact with the Netgear 2nd Level Support to find out how to solve this problem. Until now they told me that they were working in the backend to solve the problem. I disabled the gesture sensors on the canvas menu. Now that they might have a solution I can't turn it on via the app.
I'll let you know if we found out something new. If this goes on for way too long like 1 year + I'll let them refound me the wasted time because I'm literally doing their job.
