DharmaBum
May 30, 2022Guide
Images change and menus display randomly (MC327)
I recently purchased a Canvas II (MC327). Love the image quality and subscription service. Like a few others in the forum, I am experiencing random image changes and random menus popping up every few...
- Aug 29, 2022
Original poster here. Happy to say my issue has been resolved.
As others have noted, the issue is due to the gesture sensors. An updated gesture driver can solve the issue, but requires sending the unit to Netgear's San Jose, CA office for the install. Tech support was very helpful in resolving my issue. They reached out to me; I never submitted a ticket.Tech support was responsive to my questions, and followed up with me frequently.
The process was:
- Try a factory reset. This did not solve my issue.
- Disable gesture sensors. This can only be done remotely, and only by Netgear. Once the gesture sensors were disabled, my issue with images changing and random menus popping up stopped completely. I waited a week to make sure.
- With the issue confirmed as due to the gesture sensors, send the unit to San Jose CA for updated drive install. Netgear provided a free Fed Ex shipping label.
This should have been the end of the story. But for some reason, when I got my unit back the updated driver did not solve my problems. The problem persisted until I again requested the sensors be disabled.
Netgear then offered to send me a second unit, but unfortunately, it had the same problems, and I returned it. It came from their warehouse, and did not have the updated driver.
Netgear then sent me a third unit, directly from their San Jose office with the updated drivers already installed. That unit has worked perfectly, without issue. The gesture sensors are enabled and working properly, and the image does not change when "freeze image" is turned on. After testing the 3rd unit for a week, I returned my original (defective) unit to San Jose using the pre-paid shipping label Netgear provided.
For anyone experiencing this issue, I recommend submitting a support ticket and it can be resolved. At a minimum, you can request the gesture sensors are remotely disabled which makes the problem stop (albeit with the loss of the gestures). I worked with Rose in Netgear support.
karwosts
Jul 17, 2022Aspirant
Mine had a similar issue (purchased in May '22), and I believe tech support resolved it for me.
Mine would once or twice a day would change the image on its own (left or right one image), or randomly show menus, it was clear that it was an issue with the gesture sensor.
After a few rounds of the basic troubleshooting with tech support, I was told that a new firmware was developed for the gesture detection circuit which improves this issue, but that it could not be updated remotely. They sent me a label to return the canvas to them.
After having them update the firmware, they sent it back to me and it's been back in my house for a week and seems to be good so far!
Also it is possible for the gesture controls to be disabled, but it can only be done by Netgear. If you open a support ticket with them and ask it to be disabled, their backend team can do that on your canvas, but you have no control over it as the end user, you need a ticket everytime you want to change the setting.
- DharmaBumAug 29, 2022Guide
The process was:
