Jeffgear
Aug 29, 2024Virtuoso
Is Canvas end of life?
I can't source another Meural here in NZ and the main distributor says they can't get hold of any and thinks they are now an end of life product. Anyone heard if this is the case or if stocks a...
Aug 29, 2024Guru - Experienced User
I haven't heard anything on it being EOL but I have heard they might trim some of the router lines to prevent so many of the "one-offs" like the costco/walmart specials
Jeffgear
Sep 23, 2024Virtuoso
https://www.channelnews.com.au/exclusivenetgear-kills-off-meural-canvas/
“Netgear has killed off Meural, an ill-fated product that was designed to generate subscriptions from a digital picture frame similar to what Samsung has done in the past via their Frame TV.”
Shame. I hope I can still use my Canvas locally for my iCloud Photos if they kill off the subscription part of the app.
- plemansSep 23, 2024Guru - Experienced User
Thats unfortunate. I have a 24inch one I use. Guess it'll just be for my photos then
- JeffgearSep 23, 2024Virtuoso
All the resellers here have ran down their stock and deleted the product from their web site 😞 I was hoping to get another one, the smaller desktop model.
