Mick41
Jan 11, 2025Aspirant
Latest Meural app does not work on my iphone 12 using OS 18 or my ipad using OS 17.2
My iphone and my my ipad do not work with latest Meural app version 7. Just get spinning circles. Both devices were working fine with previous versions of app.
KevinLiT
Jan 24, 2025NETGEAR Moderator
Hello Ronpic,
Thank you for attempting the troubleshooting steps mentioned above!
I have escalated this issue to our experts for further analysis.
In the meantime, please try closing your your Meural app > reset your password from my.meural.com > then log into your Meural app.
Best,
Kevin
Community Team
Ronpic
Jan 24, 2025Aspirant
That worked Kevin - thank you!
Just to be clear - my iphone app was just a spinning circle until I changed the password on the computer site. Then logged in again on my iphone.
Ron
- JustinG87Jan 24, 2025GuideI reset my password as suggested (along with the previous suggestions about updating my Meural firmware) and I'm still getting the endless spinning circles in the iOS app. I've uninstalled, reinstalled, reset my password, nothing has made a difference.
- kvmayankJan 24, 2025Initiate
I changed a bunch of things in my profile (Name, City) along with the password. That fixed my app login. Can use it now. Super strange -- can not imagine why that would have fixed things, but they have 🙂
- MrStormJan 29, 2025GuideJust spoke with Negear level 2 support and have a solution that worked for me and may work for other people. Try this: login to my.netgear.com (not my.meural). Click on the person figure at the top right and select “Manage Profile” Then pick the “Edit Profile” section If your “Choose Country” is blank, set it to your correct country. Click “Save” at the bottom and go try to login to the app again The support person says this is a known issue that affects all of Netgear’s apps since they added the new one-time code security check to them. Also, setting the country has fixed it for some but not all users. We didn’t try this because Netgear support wanted the data from the Choose Country test but I bet it will also work if you turn off Two-Step Verification which can be done like this: login to my.netgear.com (not my.meural). Click on the person figure at the top right and select “Manage Profile” Then pick the “Login Setting” option Then pick “Two-Step Verification” Then uncheck “Enable” and click “Disable” in the pop-up box that appears (if you don’t have pop-ups disabled in your browser settings) Good luck.
- timojhenFeb 01, 2025Aspirant
The Mr Storm solution worked for me (thankfully). Love the device, underwhelmed with the software. Here's to hoping it's on a better path.
