JamieEH's avatar
JamieEH
Follower
Aug 12, 2020
lost cleat mounting for Meural Canvas MC227
Need a replacement cleat for mounting Meural Canvas MC227 on the wall- was on the phone for over an hour and transferred 4 times without luck.  Anyone have any idea how to replace it so I can hang it on the wall?  The swivel doesn't seem to be something my version is capable of supporting according to the instructions and pictures.
Lost the powercord too.  Tried a 12v i had and the frame flickered, so trying to find one of those too.....that is what happens when you move...you end up loosing something!
thanks-
  • plemans's avatar
    Love that you're posting it to a free 3d site. The amount of times I've popped on a site to print something simple (rc car part), its usually a have to pay for and by then, its cheaper to just order it from amazon by the time you figure paying the print, material cost, and the time or 3 you mess it up. :)
    Please post it back on here as I imagine this will be the first post that pops up if people search this topic.
  • CrimpOn's avatar
    CrimpOn
    Another solution might be to put two screws in the wall and let them stick out enough for the Meural Canval to hang from them.
    • DavidR_MI's avatar
      DavidR_MI
      Tutor
      I’ve decided to 3D model and print a replacement. It’s faster if I had an original cleat for measurements, but time isn’t a problem. The design is very straight forward.
      Once I’m successful I’ll post the file on a number of the free 3D design sites (e.g. thingaverse, printables, etc.) for everyone looking for a replacement.
      I will post here when I’m successful.
        DavidR_MI
        Tutor
        Apologize for the delay. I completed the 3D printable cleat and posted the files on printables.com
        I realized during this design & printing process that I have the MC315 model. ¯\_(ツ)_/¯
        Link to the files: https://www.printables.com/model/1794056-netgear-meural-mc315-mounting-cleat
        Hopefully it will be helpful to others.
  • CrimpOn's avatar
    CrimpOn
    Replacement parts are not one of Netgear's strengths.  Most hardware stores carry French Cleat picture hangers for under $10.
    Spend a little more and get an aluminum cleat that can be cut with a hacksaw to match the size of the hole in the back of the Canvas
      DavidR_MI
      Tutor
      CrimpOn​ THANK YOU!  I didn't realize cleats were essentially universal. Makes sense.  Again, Thank you.
  • Did you ever procure a replacement wall cleat?  I also moved and lost my wall mounting cleat in the process and looking for a replacement.
