8coyle's avatar
8coyle
Tutor
Apr 29, 2020
MC227 (gen 1) Second hand setup
https://i.imgur.com/jRMQCt6.jpg   So I picked up this frame second hand and can't get it working. I did a factory reset which might have been the mistake -- as before it had a few generic pieces of...
  • thingsrbad's avatar
    May 01, 2020
    From what I understand the original user needs to go into the meural app or website and remove the canvas from their account.
