EM1-X
Mar 22, 2024Aspirant
MC321 Higher Brightness Setting Stopped
Hi Folks, My Meural Canvas until just recently stopped displaying my photos in the highest brightness setting. I purchased this in September of 2023 so it should still be covered under warranty, ...
KevinLiT
Mar 22, 2024NETGEAR Moderator
Hello EM1-X ,
I understand that your Meural Canvas is not showing as desired. Please try factory resetting your Meural Canvas then adjust the brightness settings by changing the light sensitivity to low then turning off the auto brightness feature on your Meural Canvas.
Follow the steps below to adjust the auto brightness for your Meural Canvas through your Meural app:
- Tap CANVAS.
- Then tap the gear icon on the top right of the screen.
- Now tap Canvas Settings.
- Scroll down to Light Sensor.
- Toggle off Auto-Adjust Brightness.
- then, tap ">" icon on the right of the "Light Sensitivity" text.
- Now tap low then adjust the light settings on your Meural Canvas.
Best,
Kevin
Commuinty Team
EM1-X
Mar 23, 2024Aspirant
Thank you so much!! My lack of option awareness in the app brought me here looking for answers. I just noticed the brightness slider at the top of the app......duh! Thanks again for your helpfulness and patience.
