mfrank1's avatar
Aug 28, 2022
Merging Playlists
Is there a way to merge Playlists on the Canvas?
  • KevinLiT's avatar
    Aug 31, 2022
    Hello mfrank1,
    Welcome to the NETGEAR Community!
    I understand that you would like to merge your playlists on your Meural Canvas. At this time you are only able to transfer the photos from one playlist to the other.
    Please follow the steps below to transfer photos from one playlist to the other:
    • Navigate to my.meural.com (log into your account)
    • Select your initials on the top right of the page.
    • Select Playlists
    • Select the Playlist with the photos you would like to move.
    • Select the "three dots" under the photo
    • Select "Add to Playlist
    • Select your desired playlist
    Best,
    Kevin
    Community Team
