manesefabrizio's avatar
Feb 01, 2022
Metamask not clickable when showing NFTs
Hey,
I just got my meural 2 and i wanted to show my nfts on there. The first time i could link my meta but it never connected. now i can't even connect my metamask, it is not clickable. I am using a macbook. Whats going on?
  • Now the metamask works but i can only upload a few NFTs. When i add them it says added 0 NFT's. I asked support specifically if it was working well. It's full of bugs and unusable is there someone from support here?
    • ConnorNFT's avatar
      ConnorNFT
      I am having the same issue. 6 Loaded up, but now can't load anymore. Did you find a fix?
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello manesefabrizio  and ConnorNFT,
        Welcome to the NETGEAR Community!
        Thank you for your post!!
        We are currently working on improving NFT compatibility with our Meural products. One of our support experts will contact you in regards to this issue.
        Best,
        Kevin
        Community Team
