mikenott
Nov 25, 2020Aspirant
Meural - physical defect? White mount sticks outside frame?
Just received a Meural MC327 and noticed that the white mount within the frame ad around the display area sticks out at either end at the top by a quarter of an inch or so, It is flush with the frame in the top centre and at the bottom (in landscape mode)..
I have attached images to show what I mean.
Is this right/mormal?
Thanks
Michael
Netgear gave me a case number and so reurned via Amazon with replacement provided. Stiill has some distortion, but not as much by a long way as previous one. ooking at the frame the (wood) frame is only anchored to the display in the corners - the middle of the frame can flex quite a lot. Suspect mine was distorted during packing/storage/distribution. Also perhaps implies that frame could distort a bit over time as wood expands/contracts depending on environment it is in. Anyway, happy with new one and thanks for input.
Pictures can take a while to show up because a moderator has to improve them.
You can click on "choose file" and attach them. Then we can view them.
- mikenottAspirant
