MrStorm
Jan 22, 2025Guide
Meural App won’t complete login
The latest Meural App for iOS (7.0.0) will not complete the login process. It takes my email and password, sends a one time code, and then hangs with the spinning circles after the code is entered. W...
- Jan 29, 2025
Just spoke with Negear level 2 support and have a solution that worked for me and may work for other people. Try this:
login to my.netgear.com (not my.meural).Click on the person figure at the top right and select “Manage Profile”Then pick the “Edit Profile” sectionIf your “Choose Country” is blank, set it to your correct country.Click “Save” at the bottom and go try to login to the app againThe support person says this is a known issue that affects all of Netgear’s apps since they added the new one-time code security check to them. Also, setting the country has fixed it for some but not all users.We didn’t try this because Netgear support wanted the data from the Choose Country test but I bet it will also work if you turn off Two-Step Verification which can be done like this:login to my.netgear.com (not my.meural).Click on the person figure at the top right and select “Manage Profile”Then pick the “Login Setting” optionThen pick “Two-Step Verification”Then uncheck “Enable” and click “Disable” in the pop-up box that appears (if you don’t have pop-ups disabled in your browser settings)Good luck.
KevinLiT
Jan 27, 2025NETGEAR Moderator
Hello AJL50,
Welcome to the NETGEAR Community!
Please try the following steps to resolve this issue:
Uninstall the Meural app.
Navigate to my.meural.com and change you password
Reinstall your Meural app the log into the app using your new credentials.
Best,
Kevin
Community Team
MrStorm
Jan 27, 2025Guide
Tried deleting the app, changing my password on my.meural.com, and reinstalling the app. Looked promising for a second when the app asked if I wanted to enable FaceID but it still hangs with spinning circles after entering the one-time code. Closed the app and restaretd it to see if it would use FaceID but it still wanted an email, password, and one-time code and still hung after the one-time code was entered.
FYI: I used an iPhone 15 Max with iOS 18.2.1 (current).
I'm pretty sure it's a bug in the app (7.0.0) and not a user configuration issue.
- MrStormJan 27, 2025Guide
I've had the same problem ever since they "upgraded" the iOS app to version 7.0.0. I didn't find this topic when I first looked so I have a duplicate thread opened with the title "Meural App won’t complete login".
Apparently, they don't believe they have a bug since the only advice has been to delete and reinstall the app and change your password on the my.meural.com website. I had already tried removing and reinstalling the app but I tried it again today with the password change and it still fails exactly the same way by hanging with spinning circles after the one-time code is entered.
