Ovecarleone
Jan 25, 2022Aspirant
Meural Canvas 2 Schedule "Turn On" not working
Hello Community I got a new Meural Canvas and I may have a little issue. I set a schedule for the canvas to turn on at 06.00 PM and turn off at 11.30 PM. Now, the turning off part works fine but it ...
- Feb 02, 2022
Hi Kevin
Thank you for your reply. AS I wrote, the "Auto-Adjust Brightness" and " Sleep When Room Is Dark" ain't the problem.
I found the solution myself. It was the power mode. It was default set that after 4 hours the system wouldn't go to sleep but rather would shut down completely. After switching the power mode to sleep after 4 hours the schedule works fine.
But thank you for your help anyway.
KevinLiT
Jan 31, 2022NETGEAR Moderator
Hello Ovecarleone,
I understand that you are having issues with the Wake feature on the Meural Canvas 2.
Please follow the instructions below:
1. Open the Meural Application
2. Navigate to Meural settings
3. Turn off "Auto-Adjust Brightness" and " Sleep When Room Is Dark"
4. Then set the Scheduler for your desired times.
Please keep us informed on your progression with this issue!
Best,
Kevin
Community Team
- OvecarleoneFeb 02, 2022Aspirant
Hi Kevin
