Ovecarleone's avatar
Ovecarleone
Meural Canvas 2 Schedule "Turn On" not working
Hello Community I got a new Meural Canvas and I may have a little issue. I set a schedule for the canvas to turn on at 06.00 PM and turn off at 11.30 PM. Now, the turning off part works fine but it ...
  • Ovecarleone's avatar
    Ovecarleone
    Feb 02, 2022
    Hi Kevin
    Thank you for your reply. AS I wrote, the "Auto-Adjust Brightness" and " Sleep When Room Is Dark" ain't the problem.
    I found the solution myself. It was the power mode. It was default set that after 4 hours the system wouldn't go to sleep but rather would shut down completely. After switching the power mode to sleep after 4 hours the schedule works fine.
    But thank you for your help anyway.
