robjuge
Dec 13, 2022Aspirant
Meural Canvas cannot connect to wifi
Hi! meural Canvas. Did a factory reset, and now I can’t connect to the network. I reset one of my two meurals (had for a couple years) because of some images not loading. Now, I can’t add it ...
Dec 13, 2022Guru - Experienced User
What happens if you setup a guest network on your router and try to connect the meural to that?
- robjugeDec 13, 2022AspirantNada. Tried connecting to our internal guest network and even a wifi hotspot with all the simple, lowercase characters recommended by other posts. I don’t understand why I can’t see the meural’s internally broadcast ssid and password at all, on any device. I’ve even tried entering them as a manual “other network” with no luck.
- plemansDec 13, 2022Guru - Experienced User
If you disable the network security (leaving it open) for the ssid/network, can it connect then?
