Retired_Member
Dec 13, 2019Meural Canvas Change WIFI Network
Hi There, I'm trying to connect my Meural to a new WiFi network and am having issues. I'm following THIS article, but when I get to #9, there is nowhere to select the new network. Does somebo...
bzwench
May 14, 2020Aspirant
When you deregistered and re-registered your Meural, did you lose all of your content?
Thanks!
Thanks!
Facepalm_Meme
May 14, 2020Tutor
My content was stored in the Meural portal. When you unregister and re-register, you're just disassociating and reassociating the Meural canvas with the your account on the Meural portal. Therefore if your content is stored there, and you're using the same account, it will still be there even if you unregister and re-register.
