Millie56
Aug 23, 2021Tutor
Meural canvas continually updating
I have set the picture display duration to 1000 seconds. After uploading an image be it from the Meural website or one of my own photos the display will go blank and the image flicker with a message ...
- Feb 02, 2022
This thread is a bit older now but I'm gonna comment on how I resolved my updating issue.
First, how it all started. I set a sampler of 61 pictures as playlist which would be played from 18:00pm to 21:00pm. At 19:00pm the canvas would start to update the sampler which is the reason why it would flash every few seconds. The issue is that it seemed not to stop but it would after 1h or so.
I see this as a big issue so I deleted the sampler as playlist and started to create my own playlist with the pictures from the sampler. I was actively watching the canvas the last few days and had no update issues anymore.
Hope this helps you.
Aug 23, 2021Guru - Experienced User
Because its "updating" is your photo being updated to the device. Its your playlist/data updating.
- Millie56Aug 23, 2021TutorHi
Thanks for the quick response. I’ll take a photo of what it’s doing. The images have been on the device for a while so I don’t see a need for the photo to update however it may be the playlist updating. How would I know the difference? - Millie56Aug 24, 2021TutorHi
Thanks for the quick response. I’ll take a photo of what it’s doing. The images have been on the device for a while so I don’t see a need for the photo to update however it may be the playlist updating. How would I know the difference?- pssguySep 18, 2021Initiate
Did you get this resolved? I am having a similar issue with an image being updated a couple of times (including with the timer) before remaining on canvas. When the next image in the playlist appears the same process may or may not happen. It seems pretty random
- CottonsusanOct 06, 2021GuideI am also having this problem. I still have not seen an answer for it. Considering how incredibly expensive this item is there should be some kind of answer for this problem. I am extremely disappointed in the Customer Service, the lack of a manual, and the lack of response for any questions or problems. Having called Netgear several times about different issues with the Meural I am finding that none of their technicians I spoke with own a Meural or know how to operate one. The company really needs to make this right
