Millie56
Aug 23, 2021Tutor
Meural canvas continually updating
I have set the picture display duration to 1000 seconds. After uploading an image be it from the Meural website or one of my own photos the display will go blank and the image flicker with a message ...
- Feb 02, 2022
This thread is a bit older now but I'm gonna comment on how I resolved my updating issue.
First, how it all started. I set a sampler of 61 pictures as playlist which would be played from 18:00pm to 21:00pm. At 19:00pm the canvas would start to update the sampler which is the reason why it would flash every few seconds. The issue is that it seemed not to stop but it would after 1h or so.
I see this as a big issue so I deleted the sampler as playlist and started to create my own playlist with the pictures from the sampler. I was actively watching the canvas the last few days and had no update issues anymore.
Hope this helps you.
Aug 23, 2021Guru - Experienced User
Because its "updating" is your photo being updated to the device. Its your playlist/data updating.
Millie56
Aug 23, 2021Tutor
Hi
Thanks for the quick response. I’ll take a photo of what it’s doing. The images have been on the device for a while so I don’t see a need for the photo to update however it may be the playlist updating. How would I know the difference?
