Saif87
Mar 22, 2024Follower
Meural canvas has a browser open ion display
My meural is showing a browser page with address set to 127.0.0.1/frame. Its still connecting to the app and loading pics in this browser. Is it some sort of debug mode. How can i get rid of it? Any h...
zacN
May 17, 2025Aspirant
Problem solved by performing a factory reset of the canvas:
- You need a paperclip (or pen or other slim object) to press the reset button with
- Disconnect the power cord from your Canvas
- Locate the small/recessed reset button near the micro USB port and micro SD card port on your Canvas
- Using the paperclip, firmly press and hold the reset button
- While continuing to hold the reset button, plug the power cord back into your Canvas
- Wait 20 sec, then release the reset button
- The Canvas automatically reboots.
