joey301's avatar
Jul 25, 2022
Meural canvas help deleting pictures
The Mrural app added some “works” to my Meural that i do not want. On my ipad, i cant find out how to delete them? These are not my uploads but are new to membership pictures. Thanks
  • KevinLiT's avatar
    Jul 25, 2022
    Hello joey301,
    Welcome to the NETGEAR Community!
    I understand that you would like to remove some unwanted "Works" from your Meural Canvas. Removing unwanted works from your Meural Canvas can be done through your Merual app.
    Please follow the instructions listed below to remove the unwanted images on your Meural Canvas:
    • Open the Meural app
    • Select Canvas
    • Select Settings (top right)
    • Select Canvas Settings
    • Select Manage Art
    • Select "Edit" (top right)
    • Then tap the red "-" sign on the far left next to the unwanted works
    Best,
    Kevin
    Community Team
