Min_s
Jun 24, 2022Aspirant
Meural Canvas II available space
I created a new playlist of works from the membership library (177 works). When I try to play it, I receive a message that the Meural is out of space. I have 18.8 gb available in my cloud space, but s...
Min_s
I just tried your suggestion. Unfortunately it did not work either.
KevinLiT
Jun 24, 2022NETGEAR Moderator
Hi Min_s,
Thank you for providing that information. Please check your PM.
Best,
Kevin
Community Team
- CBon2022Oct 10, 2022Aspirant
I'm having a similar issue where I am out of space on my canvass but have 19G of cloud storage. But receiving the out of space error, even when uploading to my.meural.
- KevinLiTOct 10, 2022NETGEAR Moderator
Hello CBon22,
Welcome to the NETGEAR Community!
Please upload your photos to a playlist then send the playlist to your Meural Canvas.
Best,
Kevin
Community Team
- TacticalHipsterJan 07, 2023Tutor
Can Netgear provide clarity on how the cloud storage and onboard storage work? More specifically, how they work (or don't work) together?
If I am limited to the onboard 4GB to show works and schedule playlists, what is the point of the cloud storage? My assumption is that the Meural would dynamically move works (or playlists) on and off the onboard storage as need. Or the Meural would use the onboard 4GB as a buffer to load in whatever playlists are meant to display / scheduled.
I would makes sense to me that the scheduler would show all my playlists (not just the ones "on my Meural") allowing me to pick from anything uploaded or added to my cloud account. In the background, Meural cloud services would figure out when it would need to dump previous playlists and works according to the desired schedule. There are numerous similar examples of library cloud management services from Apple TV, Audible, Steam, etc. How is it that one of the largest network and cloud solution technology company is behind the times?
