Vic_G
Nov 26, 2019Apprentice
Meural Canvas II: Bug? Removal of SD card w/ playlists does not completely remove references
Hello, please let me know if I should be posting this elsewhere ..... Issue 1 involving SD card based playlists On SD card created 4 playlists: meural1, meural2, meural3 and meural4 with a few ...
HolgerScheller
Feb 02, 2020Aspirant
Hey Vic_G ,
seems to work now. Thanks for your response, very much appriciated! Looks like it lists the files in subfolders beneath meural1 for example but it can't display!? Very strange.
Did you ever try to connect to the micro USB? Thought I could have a look how the store pics on the internal memory. I connected the Meural to my Windows PC but nothing happens there, it can't recognize the device. Any ideas on that!?
Do you know how the store the information about the picture like Artist and the description? If possible I'd like to add that for my pics stored on the external SD card as well ;-)
Greetings for a very windy, rainy Heidelberg!
Holger
Vic_G
Feb 04, 2020Apprentice
HolgerScheller Hello Holger!
I see that Kevin has posted a reply for you on how to contact the technical support team. That is probably your best chance to find the answers. After experimenting with the SD card, we only use the web interface to create playlists and populate the Canvas. I never considered how to add Artist and Descriptive info to files on the SD card. If the tech support tells you how to do that, would you please share the answer here?
On my list of interesting things to try is to connect my Windows PC to the micro USB port, as you have already done. I have yet to finish enough of my other chores to try it though. Given your experience, maybe it is not worth my time to try it. I doubt that it is an officially supported access point but it would be useful if one could do as you were thinking and manually populate the folders on the Canvas.
The wind and rain in Heidelberg has come to Kentucky. With maybe a bit of snow in a few days!
Vic
