oguser
Sep 10, 2022Aspirant
Meural Canvas II MC327 issues connecting to wifi
As stated above, I have a Meural Canvas II MC327. It simply does not connect to wifi. Within the app it just shows "Offline" or that I need to restart WiFi. It's been a while since I've had this d...
TheDart
Feb 02, 2023Aspirant
I am having the same problem.
I did however set the canvas up on the home wi-fi and now I have taken it to work.
Do I need to setup the wi-fi on the actual canvas again so i can connect to my phone and if so how do I do that?
The gesture prompts are also so frustrating, as it rarely picked up my hand movements 😞
ArtFan
Feb 18, 2023Guide
Hello TheDart,
Here's my suggestions that may help you with your issue ("The gesture prompts are also so frustrating, as it rarely picked up my hand movements" ).
1. Place your hand near the middle point of the Canvas' frame, as close as 1" to 2".
2. Make swiping gestures (up, down, left and right) same manner as you paint with a brush, with your fingers moving like the tip of brush moves, and
your palm facing left, right, up, and down correspondingly to swipe left, right, up, down.
Keep your hand in place, don't move your arm. Just ROTATE smoothly your hand ONLY around your wrist.
3. Move your hand as slow as about 1 sec, make a pause of about 1 sec before another move.
Hope this helps.
- ArtFan
