psptktn
Oct 26, 2020Follower
Meural Canvas II playlists not working
Hi all, I just bought meural canvas ii. I have a problem with showing playslist on my canvas. Canvas will play the sampler playlist (the one it came preloaded) without any problem. If i create a ...
Christian_R
Oct 30, 2020NETGEAR Employee Retired
Hello psptktn,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
