jonathn62
Jan 05, 2020Guide
Meural Canvas II storage
I have 3 Meural canvas II's and have added images to all 3. Do the images actually get stored in the device or just on the cloud? In other words, if I turn off the wifi in my home, will the canvas ...
mattwillhill
Aug 22, 2021Guide
I found the cloud server clumsy in both upload & download and gave poor control. For me the SD card is the only way to go. The SD card has no storage limit and plays pictures in numerical file order.
To get a numerical file ‘play’ you need to use a number sequence of the same order so if you have 99 images you need to start & label image no.1 as “100” up to “199” (3 digits) if you have 9,999 images you need to use the sequence starting at “1,000” up to “9,999” (4 digits) and so on …..
- aspierAug 23, 2021Star
Thanks but in order to add pictures you have to take the meural off the wall, take out the card, put in your pc, load the pictures, etc.
Also you can't use the sleep function to go back on to the card.
So poorly designed.
- BobbolewJan 25, 2022AspirantDon’t need to remove frame from the wall. Power down the frame then unplug it from power, (this seems to make it recognize the new contents on the SD card better). Anyway, just open the SD card slot and remove the card. When ready re-install card, plug the Canvas back into the outlet and power it up. Again, no need to remove from the wall.
