jonathn62
Jan 05, 2020Guide
Meural Canvas II storage
I have 3 Meural canvas II's and have added images to all 3. Do the images actually get stored in the device or just on the cloud? In other words, if I turn off the wifi in my home, will the canvas ...
aspier
Aug 23, 2021Star
Thanks but in order to add pictures you have to take the meural off the wall, take out the card, put in your pc, load the pictures, etc.
Also you can't use the sleep function to go back on to the card.
So poorly designed.
Bobbolew
Jan 25, 2022Aspirant
Don’t need to remove frame from the wall. Power down the frame then unplug it from power, (this seems to make it recognize the new contents on the SD card better). Anyway, just open the SD card slot and remove the card. When ready re-install card, plug the Canvas back into the outlet and power it up. Again, no need to remove from the wall.
