LJ701's avatar
LJ701
Meural Canvas II usb port
Good morning, I am told that there is a usb port next to the SD card slot. Mine seems to be missing???? (see attached pic) Not sure what my next step might be. Thank you for any suggestions. LJ
  • Hello LJ701,
    I understand you are trying to access the USB port on your Meural Canvas II. Please note that the USB port on your Meural Canvas II is reserved for developer use.
    The USB port is located toward the bottom right of the reset button.
    Best,
    Kevin
    Community Team
  • plemans's avatar
    What actual model number do you have?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with for checking what features/specs it should have.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello LJ701,
    Best,
    Kevin
    Community Team
