Notorious
Jul 24, 2020Star
Meural Factory Reset
Has anyone had the guts to try the Factory Reset on a Meural Canvas II? I've had nothing but trouble with mine and am tired of wasting my time. So I thought that while waiting 4-6 weeks for an actu...
MeOrMeural
Dec 28, 2020Initiate
Same issues. I have a couple of these. When changing the wifi password the screen went into noman's land .. sorry.. "no-person's...i don't want to get canceled here.
My support is expired, i do not have confidence if i pay for support it will get solved so...I pretty much have two frames that display a purple screen.
I will keep them up for the ho;idays as conversation pieces when neighbors come over :)
*Yes I followed the NetGear instructions..
Best of luck to all of you that change you wifi password !
Christian_R
Dec 29, 2020NETGEAR Employee Retired
Hello MeOrMeural,
Welcome to the community May you send me a private message with the following info and I'll see if support can reach out to you.
Email:
Phone:
Preferred Contact Time: (including time zone)
Christian
- biswasgDec 31, 2020Tutor
Am unable to reconnect my Meural 227.
It was working fine till yesterday, when I disconnected the power supply to change the position. After reconnecting to power, the Meural does not work. The screen seems to energise but remains grey.
Trying to do a factory reset. Tried couple of times but did not succeed. Not sure, if I pressed the reset button correctly or if there is a different procedure.
Any help will be highly appreciated.
- NotoriousDec 31, 2020Star
Make sure that you have the proper format of image. Meural doesn't tell you that if you have a horizontal image, the Canvas II will only show it if the Canvas is positioned horizontally. Same for vertical. I wasted a lot of time until figuring this out. Did you get the rotating mounting plate so you can position the Canvas either way?
Thanks for your reply. Actually, my Meural was working fine for the last 2 years, always in the horizontal format. However, yesterday, I disconnected it as i installed the rotating mount. However, since I connected the power supply back, I am seeing a blank screen. I can sense that it powers on as the screen slightly illuminates, but remains blank grey.
So trying to factory reset to start again.
