Notorious
Jul 24, 2020Star
Meural Factory Reset
Has anyone had the guts to try the Factory Reset on a Meural Canvas II? I've had nothing but trouble with mine and am tired of wasting my time. So I thought that while waiting 4-6 weeks for an actu...
Christian_R
Dec 29, 2020NETGEAR Employee Retired
Hello MeOrMeural,
Welcome to the community May you send me a private message with the following info and I'll see if support can reach out to you.
Email:
Phone:
Preferred Contact Time: (including time zone)
Christian
biswasg
Dec 31, 2020Tutor
Am unable to reconnect my Meural 227.
It was working fine till yesterday, when I disconnected the power supply to change the position. After reconnecting to power, the Meural does not work. The screen seems to energise but remains grey.
Trying to do a factory reset. Tried couple of times but did not succeed. Not sure, if I pressed the reset button correctly or if there is a different procedure.
Any help will be highly appreciated.
- NotoriousDec 31, 2020Star
Make sure that you have the proper format of image. Meural doesn't tell you that if you have a horizontal image, the Canvas II will only show it if the Canvas is positioned horizontally. Same for vertical. I wasted a lot of time until figuring this out. Did you get the rotating mounting plate so you can position the Canvas either way?
- biswasgDec 31, 2020Tutor
Thanks for your reply. Actually, my Meural was working fine for the last 2 years, always in the horizontal format. However, yesterday, I disconnected it as i installed the rotating mount. However, since I connected the power supply back, I am seeing a blank screen. I can sense that it powers on as the screen slightly illuminates, but remains blank grey.
So trying to factory reset to start again.
Just to make sure, perhaps you should
- Restart your Canvas, either by using the button on the frame or by unplugging and plugging it in again.
- Then use "Send to Canvas" to send one horizontal image.
- Then (if screen is still gray after 60 seconds or so) restart Canvas again.
- Cross your fingers.
Did you have any luck contacting Meural via the info they provided? Support is shockingly bad. Like a lot of other companies, they're trying to increase profits by outsourcing support to other struggling users. Shame on them.
