Notorious
Jul 24, 2020Star
Meural Factory Reset
Has anyone had the guts to try the Factory Reset on a Meural Canvas II? I've had nothing but trouble with mine and am tired of wasting my time. So I thought that while waiting 4-6 weeks for an actu...
LuisLamim
Apr 22, 2025Aspirant
I´ve the same problem since 5 years,
Very stupid software, I even could not delete the trial family pictures. I was sure it would be flexible to add and remove picture but not.
I´m very disappointed with this product as well.
- NotoriousApr 22, 2025Star
One thing they don't tell you is that if you have both vertical and horizontal images, you'll have trouble. If your Meural is in a vertical (portrait) orientation and you try to show a horizontal (landscape) image, it doesn't inform you of the error; it just chokes and leaves you wondering what's wrong. Try putting all your vertical images in one set and all the horizontal into another.
