Notorious
Jul 24, 2020Star
Meural Factory Reset
Has anyone had the guts to try the Factory Reset on a Meural Canvas II? I've had nothing but trouble with mine and am tired of wasting my time. So I thought that while waiting 4-6 weeks for an actu...
LuisLamim
Apr 22, 2025Aspirant
I´ve the same problem since 5 years,
Very stupid software, I even could not delete the trial family pictures. I was sure it would be flexible to add and remove picture but not.
I´m very disappointed with this product as well.
Notorious
Apr 22, 2025Star
One thing they don't tell you is that if you have both vertical and horizontal images, you'll have trouble. If your Meural is in a vertical (portrait) orientation and you try to show a horizontal (landscape) image, it doesn't inform you of the error; it just chokes and leaves you wondering what's wrong. Try putting all your vertical images in one set and all the horizontal into another.
