drframe
Jun 27, 2024Aspirant
Meural II SD card issues
I am trying to display pictures from an SD card in my Meural II. I have read through several posts and have followed all of the suggestions with no luck. The SD card is 128 Gb and class10. I init...
KevinLiT
Jun 28, 2024NETGEAR Moderator
Hello drframe ,
Welcome to the NETGEAR Community!
I understand that you are having issues with your SD card for your Meural Canvas. Please start the troubleshooting process by ensuring that your system is up to date. Then reformat your SD card to "FAT32" and add one folder named "meural1". Then, add your photos with the compatible formats to the "meural1" folder and insert your SD card.
Please follow the steps listed below to update your Meural Canvas:
Navigate to my.meural.com
Select your initials on the far right
Select Canvases
Scroll down to Canvas Software Version
Select the arrow on the right of the software version
Select update on the top right
Additionally, ensure that all photos are formatted with one of the following extensions:
.jpg
.jpeg
.png
.bmp
.svg
.gif
.avi
.mkv
.mp4
.mov
.heic (iOS Live Photos).
For more information about compatible formats for your Meural Canvas please navigate to the link below:
https://kb.netgear.com/000060767/Which-image-and-video-formats-does-the-Meural-support
Best,
Kevin
Community Team
drframe
Jun 28, 2024Aspirant
Hello,
FAT32 is not an option on a 128GB SD card as it is limited to 4GB. I have tried FAT32 on small cards without success. The pictures are named "picture1.jpg", "picture2.jpg", "picture3.jpg".......... I have also tried several other SD cards of different sizes and speeds with no luck.
Please provide other options.
Thank you
- KevinLiTJul 01, 2024NETGEAR Moderator
Hello drframe,
Thank you for update!
Were you able to check the firmware on your Meural Canvas to ensure that it is the most current released firmware?
Best,
Kevin
Community Team
- drframeJul 02, 2024Aspirant
Yes, I have verified that the Meural has the latest firmware. It is also set to autoupdate.
Thank you,
- KevinLiTJul 02, 2024NETGEAR Moderator
Hello drframe,
Thank you for confirming this information!
Please check your private messages for additional information.
Best,
Kevin
Community Team
