drframe
Jun 27, 2024Aspirant
Meural II SD card issues
I am trying to display pictures from an SD card in my Meural II. I have read through several posts and have followed all of the suggestions with no luck. The SD card is 128 Gb and class10. I init...
drframe
Jun 28, 2024Aspirant
Hello,
FAT32 is not an option on a 128GB SD card as it is limited to 4GB. I have tried FAT32 on small cards without success. The pictures are named "picture1.jpg", "picture2.jpg", "picture3.jpg".......... I have also tried several other SD cards of different sizes and speeds with no luck.
Please provide other options.
Thank you
KevinLiT
Jul 01, 2024NETGEAR Moderator
Hello drframe,
Thank you for update!
Were you able to check the firmware on your Meural Canvas to ensure that it is the most current released firmware?
Best,
Kevin
Community Team
- drframeJul 02, 2024Aspirant
Yes, I have verified that the Meural has the latest firmware. It is also set to autoupdate.
Thank you,
- KevinLiTJul 02, 2024NETGEAR Moderator
Hello drframe,
Thank you for confirming this information!
Please check your private messages for additional information.
Best,
Kevin
Community Team
- dsgmouradJul 23, 2024Aspirant
I have seen a similar picture when trying to run a SD card.
The SD card was working fine & all extensions of the correct file type. I added some new pictures & saw that broken SD image when going through the photos.
Also, to check on the size of the photos is there a size guide? I didn't have issues with high-resolution photos, but it seems like the file size need to be lower.
