PhotoBear
Jan 18, 2025Tutor
Meural iOS/iPad App cannot login (Jan 2025)
 Not sure what has happened, but neither my iOS or iPadOS Meural app can login to Meural/Netgear. It used to work and I can still login via the web so my login details are fine.     In the app I can e...
- Feb 11, 2025
If you login to my.meural.com, and go to your profile, and select your country code, then the Meural app will complete login. This worked for me evidently the new software requires the country code be selected.
AJL50
Jan 24, 2025Guide
I have the same problem. No login completion
canvas_user9218
Jan 26, 2025Aspirant
Having the same issue. After following the above instructions here (factory reset canvas, reinstall mobile app). After attempting to pair my canvas to my home wifi, the app shows, "wrong network name or password"
I have tested and confirmed my network and password are correct with other devices.
Have tried using both the QR code or manually entering the Product key. Neither work.
I am not able to get the app to connect the frame to my mobile phone. The meural will only show the welcome screen with QR code.
Canvas Software Versio: 2.0.3
Web App Version: v5.0.1
iPhone, iOS version: 18.2.1
