PhotoBear
Jan 18, 2025Tutor
Meural iOS/iPad App cannot login (Jan 2025)
 Not sure what has happened, but neither my iOS or iPadOS Meural app can login to Meural/Netgear. It used to work and I can still login via the web so my login details are fine.     In the app I can e...
- Feb 11, 2025
If you login to my.meural.com, and go to your profile, and select your country code, then the Meural app will complete login. This worked for me evidently the new software requires the country code be selected.
Ccrsylte
Jan 28, 2025Aspirant
I am having the same problem and have tried all the suggestions. Netgear please fix this!
