PhotoBear
Jan 18, 2025Tutor
Meural iOS/iPad App cannot login (Jan 2025)
Not sure what has happened, but neither my iOS or iPadOS Meural app can login to Meural/Netgear. It used to work and I can still login via the web so my login details are fine. In the app I can e...
- Feb 11, 2025
If you login to my.meural.com, and go to your profile, and select your country code, then the Meural app will complete login. This worked for me evidently the new software requires the country code be selected.
AJL50
Feb 11, 2025Guide
PhotoBear
Feb 11, 2025Tutor
Thanks AJL50, that worked for me!
Some pretty bad programming expecting a user to fill in optional profile stuff and then basing a login success on that rather than having a default to not filled in.
