PhotoBear
Jan 18, 2025Tutor
Meural iOS/iPad App cannot login (Jan 2025)
 Not sure what has happened, but neither my iOS or iPadOS Meural app can login to Meural/Netgear. It used to work and I can still login via the web so my login details are fine.     In the app I can e...
- Feb 11, 2025
If you login to my.meural.com, and go to your profile, and select your country code, then the Meural app will complete login. This worked for me evidently the new software requires the country code be selected.
KKArt
Mar 10, 2025Aspirant
This worked!   I’ve spent weeks logging in and out, updating passwords, resetting WiFi and Meural.  I could login from web but not app.  App kept spinning.
when I read this suggestion I thought there was no way the fix could be so obscure.
 I entered my profile name, country, zip code from the web, all which had been blank for years..  Tried the app and it flippin worked!
How the heck did you figure this out?
thank you!
AJL50
Mar 10, 2025Guide
I can’t take credit. I just saw the answer in another thread.
Alan
