PhotoBear
Jan 18, 2025Tutor
Meural iOS/iPad App cannot login (Jan 2025)
Not sure what has happened, but neither my iOS or iPadOS Meural app can login to Meural/Netgear. It used to work and I can still login via the web so my login details are fine. In the app I can e...
- Feb 11, 2025
If you login to my.meural.com, and go to your profile, and select your country code, then the Meural app will complete login. This worked for me evidently the new software requires the country code be selected.
Snerg
Mar 25, 2025Aspirant
Just to add to this - I was having the same issue as above (login, endless spinner) and when logging into my.netgear.com I found that my country was already set (and two-factor auth also disabled. However, my first and last name were listed as "undefined" and the address was also empty, and after filling in the name, address, etc., the login in the iOS app worked again.
So it's very possible that entering the profile information, or just updating the profile, is enough to solve the login problems.
