CanvasSuks
Dec 23, 2020Guide
Meural photo freeze needed
Help, Im seriously considering sending this thing back to the ninth ring of hell where this app came from. No matter how I try, using sd cards or uploading albums. I cannot get the frame to allow me ...
Christiegil
Dec 27, 2020Tutor
I’m having the exact same issues! The app and software are horrible!!!
- steveswDec 27, 2020NETGEAR Expert
The issue may be related to the scheduler being enabled which is triggering new Playlists to start.
Typically, the scheduler can be turned on in the Canvas -> Settings screen in the App.
However, it looks like there is an issue in the App (both iOS and Android) which does not allow the scheduler to be disabled.
To get around this, you can login to my.meural.netgear.com using the same email & password for the app.
Then click on circle in top right corner and select "Canvases"
Then choose Canvas you are having issue with (if you have more than one).
Then select "Scheduler" and set the slider to 'Off' position.
- ChristiegilDec 27, 2020TutorI turned the scheduler off a few hours ago and now it’s changed the picture again. So that solution didn’t work.
- CanvasSuksDec 27, 2020Guide
Thank you for the informaion but this is not fixing the issue. I have deleted the app from my phone and am only using the website. The sced. is turned off and it still changes photo for no reason. I really have no words for the poor software connected to the canvas.
If there is no fix to this and other problem I wish support would just say so. I have invested over 20 hours trying to correct issues.
- Christian_RDec 30, 2020NETGEAR Employee Retired
Hello Meural users,
For those experiencing issues, I would recommend factory resetting your Meural. Please let me know if the issue persists.
Christian
