CanvasSuks
Dec 23, 2020Guide
Meural photo freeze needed
Help, Im seriously considering sending this thing back to the ninth ring of hell where this app came from. No matter how I try, using sd cards or uploading albums. I cannot get the frame to allow me ...
stevesw
Dec 27, 2020NETGEAR Expert
The issue may be related to the scheduler being enabled which is triggering new Playlists to start.
Typically, the scheduler can be turned on in the Canvas -> Settings screen in the App.
However, it looks like there is an issue in the App (both iOS and Android) which does not allow the scheduler to be disabled.
To get around this, you can login to my.meural.netgear.com using the same email & password for the app.
Then click on circle in top right corner and select "Canvases"
Then choose Canvas you are having issue with (if you have more than one).
Then select "Scheduler" and set the slider to 'Off' position.
Christiegil
Dec 27, 2020Tutor
I turned the scheduler off a few hours ago and now it’s changed the picture again. So that solution didn’t work.
