Retired_Member
Oct 02, 2020Meural Picture Changing Randomly
I have my Meural hanging in portrait mode. In the last few weeks the picture has started to randomly change on its own. It flips to the next image in the playlist. Then that image might radomly flip ...
Retired_Member
Dec 13, 2020Update: After working directly with customer support I was able to get my canvas stabilized. They said it might have been dust in the power button that was causing the issue. They had me power off the canvas for 30 minutes. I sprayed duster in every crack. Then they told me to press the power button on and off rapidly a few times before powering it on. I went through this process a couple of times before the issue went away completely. Best of luck.
- malofloraJan 26, 2021Aspirant
Hi all,
Could I check please if this is still working as a fix - I'm having exactly the same issue.
Thanks!
