Retired_Member
Oct 02, 2020Meural Picture Changing Randomly
I have my Meural hanging in portrait mode. In the last few weeks the picture has started to randomly change on its own. It flips to the next image in the playlist. Then that image might radomly flip ...
Retired_Member
Apr 24, 2021Update #2: I solved my issue completely. It wasn't a problem with the software, it was the frame. Mine hangs vertically. That puts the horizontal gesture controls on the right hand side. I noticed that the frame was slightly warped and touching the screen on that side. Guessing that it may have happened when I laid it face down to attempt a factory reset or maybe changes in temperature. Who knows. I GENTLY pulled up on that side of the frame until it no longer touched the screen. The picture hasn't changed at all since then. Been months now.
I understand how frustrating this is. It was driving me nuts. Good luck!
JuliaTruchsess
Apr 24, 2021Tutor
Thanks for posting your findings. After having explored all available software solutions, I was wondering if it might be related to the gesture-sensing hardware. I will have a look at my frame.
