Hipchelle
Feb 28, 2020Follower
Meural Power Cord
I’m trying to extend the power cord for my canvas. Can I use a DC 12v extender with an AC power adapter? Or, can we purchase a longer power cord for the canvas?
therealcmj
Mar 01, 2020Guide
The Meural uses a 2.1mm x 5.5mm barrel connector. You can search for an extension cord for that and you should be good. Just remember that voltage drops over the length of the cable so don't go crazy with the length.
KevinJ_K
Mar 03, 2020NETGEAR Employee Retired
DISCLIAMER - Also, using a third party product that is not tested or approved by NETGEAR may or may not work and is at the customer's own risk. It is possible that the warranty could be voided if said product causes any issues or problems with th Meural Canvas.
Kevin K., NETGEAR Meural Community Team
