Mojomania
Aug 31, 2020Aspirant
Meural Resizing My photos
I understand that the resolution of the Meural Canvas is 1920x1080 pixels. I don't want Meural to auto-size the photos to fit the frame because it distorts the photo. I used Photoshop to edit all of ...
- Aug 31, 2020
Hello Mojomania,
You should be able to change this setting by following the steps below
- log into the Meural App
- Click on Canvas
- Click the Settings icon in the upper right hand corner of the screen
- Scroll down to find "Display" settings
- Change Fill Mode to Contain or As is
Try this out and let us know if you're now able to view your images in the desired format.
Kind Regards,
Christine
ChristineT
Aug 31, 2020NETGEAR Employee Retired
Hello Mojomania,
- Click on Canvas
Kind Regards,
Christine
Mojomania
Sep 01, 2020Aspirant
That was perfect. Thanks so much.
