DharmaBum
May 17, 2024Guide
Multiple canvas in different locations
Can I use a single meural subscription for two devices that are located in different locations/networks (e.g. one at work, and one at home)? Thanks.
- May 17, 2024
Hello DharmaBum ,
Thank you for the clarification!
After then initial network configuration of your Meural Canvas you will be able to manage it from my.meural.com. Be sure to select the desired Canvas before making changes.
Please follow the steps below to select your desired Meural Canvas:
- Navigate to my.meural.com.
- Click the initial on the right side of the box with the "+" symbol.
- Then Select Canvases.
- Now select the ">" icon next to your Meural Canvas's name.
- Finally, Select your desired Meural Canvas.
Best,
Kevin
Community Team
KevinLiT
May 17, 2024NETGEAR Moderator
Hello DharmaBum,
Welcome to the NETGEAR Community!
I understand that you would like to use multiple Meural Canvas devices on your Meural membership. This can only be achieved when the Meural Canvases are added to the same account as the account with Meural membership and connected to a network.
Please follow the directions below to add additional Meural Canvas devices to your Meural account:
- Navigate to https://my.meural.com/.
- Then, Click Add Canvas.
- Then, Input your canvas product key or serial number (This can be found at the back of your Meural Canvas next to the "Meural" logo).
- Now simply follow the prompts to complete your Meural setup.
Best,
Kevin
Community Team
KevinLiT
Hello DharmaBum ,
Best,
Kevin
Community Team
- DharmaBumAug 12, 2024Guide
OP here. A follow-up in case anyone was wondering the same thing... This was super easy. No problem setting up devices in different locations on different networks. Both are visible from the mueral app. I can manage both devices from the app with a single log on, even though they are in different locations. I can upload pictures to either device remotely. The app asks you which device you want to send the pictures too. Very easy. Thanks!
