DharmaBum's avatar
May 17, 2024
Multiple canvas in different locations
Can I use a single meural subscription for two devices that are located in different locations/networks (e.g. one at work, and one at home)? Thanks.
  • KevinLiT's avatar
    KevinLiT
    May 17, 2024
    Hello DharmaBum ,
    Thank you for the clarification!
    After then initial network configuration of your Meural Canvas you will be able to manage it from my.meural.com. Be sure to select the desired Canvas before making changes.
    Please follow the steps below to select your desired Meural Canvas:
    1. Navigate to my.meural.com.
    2. Click the initial on the right side of the box with the "+" symbol.
    3. Then Select Canvases.
    4. Now select the ">" icon next to your Meural Canvas's name.
    5. Finally, Select your desired Meural Canvas.
    Best,
    Kevin
    Community Team
