BLisaLisa
Nov 20, 2024Aspirant
My photos are not showing on Model# MC327BL-100PAS
The sample photos are only showing on my canvas, how do I get my photos to show? It use to work but it hasn’t in a while. I am connected to it but it’s not showing my linked album. HELP 🙂
1 Reply
- merry867Aspirant
Hello,
It seems like you’re having trouble with a device or software feature (likely related to the MC327BL-100PAS model) not displaying your photos as it used to. Here's how you can troubleshoot the issue:
Steps to Resolve:
Check the Connection:Ensure that the device is properly connected to your network or the relevant source (e.g., Wi-Fi, Bluetooth).
If possible, disconnect and reconnect to refresh the connection.
Verify Photo Source Settings:Check the settings on your device or app to ensure the correct album or folder is linked.
Make sure the permissions for the photo album are granted (e.g., access to your gallery or cloud service like Google Photos or iCloud).
Update Software/Firmware:Confirm if there are any pending updates for the device or app controlling the display. Outdated software can cause compatibility issues.
Look for firmware updates specific to the MC327BL-100PAS.
Restart Everything: myaarpmedicare loginRestart the device displaying the photos and the source device (e.g., phone, tablet, or computer).
If it’s connected to a cloud service, try logging out and back into the service.
Re-link the Album:Go into the settings and remove the linked album, then re-link it.
Ensure the album is synced and contains supported photo formats.
Check Storage or Memory:If the device has storage limitations, clear some space to ensure proper functionality.
If it’s reliant on an SD card or external storage, ensure the card is properly inserted and functioning.
Test with a Different Album:Try linking another album to determine if the issue is with the current album or the device.
Best Regards
merry678
