Dave5150
Apr 23, 2023Aspirant
My playlist is playing, but I do not see it in the app? Any help on how to see and edit it?
- Apr 25, 2023
Hello Dave5150 ,
Welcome to the NETGEAR Community!
Please ensure that you are using the latest released version of your Meural app. You can verify that your Meural app is up to date by visiting the app store (iOS) or the Play Store (Android). If you not prompted to update your Meural app you are using the current version. If you are prompted to update, then ensure that your Meural app is updated.
Please follow the steps below to edit your playlist through your Meural app:
Tap your Library (located at the bottom of the app).
A list of your playlist will display.
Please let me know if you require additional assistance!
Best,
Kevin
Community Team
KevinLiT
Apr 25, 2023NETGEAR Moderator
Hello Dave5150 ,
Best,
Kevin
Community Team
- Dave5150Apr 25, 2023Aspirant
Updating the app did the trick. Thank you so much!!
