Dave5150's avatar
Dave5150
My playlist is playing, but I do not see it in the app? Any help on how to see and edit it?
  • KevinLiT's avatar
    Apr 25, 2023
    Hello Dave5150 ,
    Welcome to the NETGEAR Community!
    Please ensure that you are using the latest released version of your Meural app. You can verify that your Meural app is up to date by visiting the app store (iOS) or the Play Store (Android). If you not prompted to update your Meural app you are using the current version. If you are prompted to update, then ensure that your Meural app is updated.
    Please follow the steps below to edit your playlist through your Meural app:
    Tap your Library (located at the bottom of the app).
    A list of your playlist will display.
    Please let me know if you require additional assistance!
    Best,
    Kevin
    Community Team
